WELDING ON A 928
Posted: Sat Jan 23, 2021 1:50 pm
by Shifted
Re: Welding on a 928
Posted: Sat Jan 23, 2021 1:57 pm
by Scott at Team Harco
Were they using galvanized steel on the car you plan to weld on? If so, you'll want to brush-up on how to do that safely.
Posted: Sat Jan 23, 2021 2:04 pm
by Shifted
Posted: Sat Jan 23, 2021 6:25 pm
by SeanR
Yes. Pull the battery cables off, unplug your LH/EZK and grind off the galvanizing at the location you are going to weld and you will be fine.
Posted: Thu Jan 28, 2021 6:03 pm
by Shifted
Posted: Fri Jan 29, 2021 9:44 am
by SeanR
Shifted wrote: ↑Thu Jan 28, 2021 6:03 pm
For reference, I disconnected the battery and put my ground within a few inches of the weld. No issues with any of the electronics when I reconnected the battery and started it up to put it on the lift. Disconnecting the computers isn't something you normally ever have to do on any vehicle.
Uh, except there are several documented cases of this being an issue. Why do you ask for advice and then just do what you want to do, ignoring what others have experienced? Disconnecting the LH/IZK takes what, 20 seconds?
Posted: Fri Jan 29, 2021 10:21 am
by Shifted
