Crumpler wrote: ↑Fri Jan 01, 2021 4:48 pm
Also, it sounds like that is an area where you do expect to see a coolant leak, given time/materials/design.
Unfortunately yes. I expect them to last 10-15 years with some 'seepage' towards the end. I recall seeing 1 or 2 that were beginning to seep 'round 8-ish years and 30k+ miles.
I'd have to go back in my records and see the 'oldest' intake refreshes I've done to get good data. And off the top of my head I don't know when I'm 'expecting' them to be in need of a second round. But, I'd guess that there are a lot of 2005-2010 intake refreshes that have reached the 10-15 year threshold. On the other hand, some of those 928s have changed hands, been totaled, or just vanished etc. The at-hand data point might be my '91 which got it in 2007. But, it's on a storage lift. So, I can't just run and check it.
I guess I was disappointed in the timeframe. Maybe the track days have accelerated the changes.
I think that's a 'tough spot' for a big rubber gasket of unknown-but-presumably-70s-materials selection to live. I expect that the expansion rates of the bridge and block are quite different and obviously there are wide temperature transitions. So, it's possibly getting heat shocked and "crushed" every time the block transitions to operating temperature.
AND it has to be resistant to coolant. Come to think of it, I wonder if the coolant age (depletion of the additive package) effects the lifetime of the gasket. The coolant may also limit choices of materials. Less so today than 40 years ago. But, coolants and their additive packages have to take into account every material touched by it.
In any case, while I see them seep at various rates, I've never had one 'fail' a cooling system pressure test cold. So, this supports my theory that the seepage occurs during warmup due to loss of plasticity and differential expansion rates. Of course, it may leak a bit when hot, but the coolant will evaporate.
Lot's of speculation their.
