How do you guys pull lifters out of the head?
Posted: Thu Dec 31, 2020 11:04 am
by Scott at Team Harco
Asking for a friend...
Re: How do you guys pull lifters out of the head?
Posted: Thu Dec 31, 2020 12:28 pm
by amdavid
Posted: Thu Dec 31, 2020 2:05 pm
by SeanR
Small, clean magnet after marking their location.
Posted: Thu Dec 31, 2020 2:07 pm
Magnet into labeled egg crates.
Unless lifters are being replaced. Then...
... magnet into bucket.
Posted: Thu Dec 31, 2020 9:12 pm
OK - I would guess I've always used a magnet in the past. For some reason, I had it in my head that that was not recommended. I won't worry about it. And seeing the first video (thanks David) - I might just as well get new VR6 lifters. After all, if a YouTube mechanic recommends it, it must be good.
So now I have to ask about the cam bridges (special tool 9226). I'll do a google on that and see what comes up. I'm sure the Chinese have a $25 kit available on Amazon...
Just to share a little - maybe you guys have seen this guy's videos. They're actually pretty good. He provides the important details, without the crap. It's even entertaining with the sound on. :beerchug:
Posted: Sat Jan 02, 2021 10:57 am
I ended up using channel lock pliers. The grease that my shop used to keep them lubricated had effectively turned to cement in the cold. Since I don't plan to reuse them, any damage is irrelevant.
Now I need to get the block studs out. The place that fixed the bores put incorrect length studs in my block. :banghead:
