Center console help and history
Posted: Mon Dec 21, 2020 11:24 am
Hello Open Roaders. This post is a search for knowledge (in more ways than one).
I am re-covering my '91's major interior parts with custom leather as a DIY. An additional goal is not to disable the car while the excessively long DIY process is underway. So I bought a used pod first and it was a minor success once I actually managed to finish it. But putting the new one in was really tough - got some pro help or my heirs would have had to do it. (Pro - you know who you are and thanks for saving my butt)
I can do the wheel because it's relatively easy to take it off, cover it, and put it back. I have a spare dash that I can work on until the refinishing is satisfactory then swap for the stock dash. But a spare console has been tough.
Ideally, I am looking for someone's surplus 90+ LHD airbag-dash-style console. If there is anyone who has one they're willing to part with please get in touch. Some cheapish OB consoles are available, and some pricier later years.
Failing that I am looking for info on the changes year-over-year. I know the shape of the passenger side corner changed but it is it just radius-ed vs square or did the dimensions change also? Are the brackets similar? Are the mounting slots the same for radio, a/c, etc., etc...
Pics on the net are not definitive. The borrowed 91 sample I have looks like the bracket on that side was ground at the factory with a Dremel to make it fit. If I can shape a cheap OB part similarly that is one way to make it work.
Thoughts? And many thanks in advance...
