2011 Cayenne rear wiper acting up
Posted: Sun Dec 13, 2020 9:02 pm
by fpena944
My Cayenne Turbo's rear wiper has been acting a little strange lately. It just starts up and then will stop right in the middle of it's cycle. Then I try to turn it off and it still doesn't really respond immediately.
I've heard that the wiper motor might need replacement when these types of issues come up. Anyone else had this happen? Has the motor fixed the issue?
Re: 2011 Cayenne rear wiper acting up
Posted: Wed Dec 16, 2020 7:08 pm
by DAVfoto
No issue with mine yet. Mine goes out of warranty in 3 weeks, so may try to have mine looked at week before New Years Eve.
I would probably think the motor is going out and it's shorting out or seizing up mid cycle.
Posted: Thu Dec 17, 2020 1:54 pm
by amdavid
Yeah, no issues here yet. We shall see. Let us know your outcome.
Posted: Thu Dec 17, 2020 2:29 pm
by fpena944
New motor came in last night but not sure I'll get to it today - maybe tomorrow and then I'll report back!
Posted: Tue Feb 23, 2021 9:51 pm
by wwilliams888
I had this happen. Wiper would spontaneously turn on and off by itself and wouldn’t go back to the home position on my 2013 base. Turned out the wiper fluid had leaked into the gear housing corroding the position contacts. Replacing the wiper motor assembly fixed the problem. The most difficult part was getting the wiper arm off of the shaft since it is a press fit. With the right arm puller I got it off, but it took a lot of pressure to get it to pop off. The rest of the repair was relatively straight forward.
Posted: Tue Feb 23, 2021 10:07 pm
by fpena944
wwilliams888 wrote: ↑Tue Feb 23, 2021 9:51 pm
Oops forgot to close this out!
The new assembly fixed the problem but like you said removing the arm was the most difficult part. Worst of all I had to do it twice because I put it on the wrong direction the first time. So it was cleaning the license plate instead of the window
All fixed now!
Posted: Fri Mar 05, 2021 11:37 am
by wwilliams888
For future reference, here is the parts diagram. I replaced the motor assembly (7). The washer fluid attaches to the back of the motor assembly and squirts coaxially thru the wiper arm shaft. If it leaks internal to the motor assembly, it will screw up the home position contacts of the wiper arm. That’s what happened to me. The nozzle (5) often clogs but is cheap and easy to replace.
