PSD Bleeding
Posted: Fri Nov 06, 2020 4:48 pm
by Sazerac
Hi All
Cheers, John
Re: PSD Bleeding
Posted: Fri Nov 06, 2020 10:24 pm
Sazerac wrote: ↑Fri Nov 06, 2020 4:48 pm
Hi All
Cheers, John
Since
Kroon makes replacement LH wiring harnesses, they must also have a supply of the 02 connectors. So, on my "to do" list is a task to contact them and ask. But, you can feel free to beat me to it. My need is a contingency not an emergency.
Re: PSD Bleeding
Posted: Mon Nov 09, 2020 5:52 pm
by Sazerac
Re: PSD Bleeding
Posted: Tue Nov 10, 2020 5:30 pm
Re: PSD Bleeding
Posted: Fri Dec 25, 2020 6:46 pm
by Sazerac
Re: PSD Bleeding
Posted: Fri Dec 25, 2020 6:54 pm
by SeanR
The hammer will charge/work when it is plugged in to the car. Mine has a bad battery but can use it once it’s on the car.
Re: PSD Bleeding
Posted: Fri Dec 25, 2020 7:08 pm
Thanks for bumping this.
Kroon should have them.
Re: PSD Bleeding
Posted: Fri Dec 25, 2020 7:10 pm
by SeanR
Outside air temp sensor for the HVAC.
Re: PSD Bleeding
Posted: Fri Dec 25, 2020 7:14 pm
SeanR wrote: ↑Fri Dec 25, 2020 7:10 pm
Re: PSD Bleeding
Posted: Sat Dec 26, 2020 4:22 am
by Sazerac
Re: PSD Bleeding
Posted: Mon Dec 28, 2020 3:08 pm
Sazerac wrote: ↑Sat Dec 26, 2020 4:22 am
Re: PSD Bleeding
Posted: Wed Dec 30, 2020 5:18 pm
by Sazerac
Perfect, thanks.
I'll get on this.
