Window switch operation is intermittent
Posted: Thu Oct 29, 2020 8:41 am
by fpena944
The driver's side window switch on my 2011 Cayenne is acting up randomly.
Is there a fix for this or should I just remove and replace the entire unit?
This is what it looks like:
Re: Window switch operation is intermittent
Posted: Thu Oct 29, 2020 9:32 am
by amdavid
Good question. I’m guessing entire unit, however I’m sure someone with fiddle time has figured out a work around.
Posted: Thu Oct 29, 2020 10:17 am
by NCporsche
First, trying spraying some contact cleaner in the switch.
If that does not work, order the replacement but do not open the box.
Remove old switch and take it apart to clean. Put it back together and see if it works.
If it does, return new switch. If it doesn’t then replace it.
Posted: Thu Oct 29, 2020 11:33 am
by amdavid
^^Yeah, yeah, good call^^. Tuner/contact cleaner, and nice on the "keep the box" suggestion.
Posted: Thu Oct 29, 2020 12:10 pm
by fpena944
Less than $200 on Partsgeek plus looks pretty easy to pop out and replace. Will do what
@NCporsche suggested, thanks!
Posted: Thu Oct 29, 2020 12:12 pm
by NCporsche
