By fpena944 - Wed Aug 11, 2021 11:53 am
#97287
The two servers, both old and new, are now running in parallel.
So this is where it gets a bit tricky. At some point soon the switch is going to take place between old to new, when that happens SOMETIMES your local PCs lock into the old server which will still be running. If this happens you won't see new messages coming in and anything you post won't appear in the new environment.
This can be pretty confusing so what I'm going to do is create a big notification on the old server stating, "YOU ARE ON THE OLD SERVER" and then have you reset your settings so you can find the new server.
Here are instructions on resetting this if you are on a computer:
https://phoenixnap.com/kb/how-to-flush-dns-cache
For phones try this link:
https://help.dreamhost.com/hc/en-us/art ... or-Android
Generally you'll be sent to the new site pretty much immediately but sometimes these changes take time to propagate.
I'll post another announcement letting everyone know they're on the right server when it all is done.
Apologies for the messy nature of this but hopefully the last move for a while.
