It would take a couple revolutions to start when hot for awhile now.
However, it's been getting progressively worse recently. Occasionally get a raw fuel smell after shutting the car off. Fuel lines are ~5 & 1/2 years old and I haven't found a leak there.
So replace the fuel pressure regulators and dampener?
:hitfan:
#97136
I've been finding more and more FPR's and dampers failing on our cars. Expensive for sure if you are going with Bosch. There are a couple of aftermarket options floating around and I've used the ones Roger is selling with good results.
