The barrel connectors are. Coming apart in a lot of cars. I found a triple sealed 6 pin twist lock connector that will fit inside the barrel connector clamp out of sight for those that are looking for a good quality connector.
Connectors are about $8 each side
Pins are about $1 each for good quality gold pins.
Total cost is about $30 per connector .
They are pretty nice pieces and I’m using them in a couple of places for my new ECU installation.
They are available @ mouser.com
Nice!
The deterioration of the connectors on the ABS/BPW/RDK harness is going to become a pandemic in this coming decade.
It kinda sucks though that one has to modify 2 or 3 senders in the wells and 2 or 3 connectors at the other end for each wheel well to make any alternative connector work.
But, it is what it is.
ROG100 wrote: Fri Jul 30, 2021 9:19 am Two companies are working on making new connectors and complete ABS harnesses. Soon we will have replacements. The hardest part was the connector.
Keep us informed!
