By captainOCD - Mon Jul 05, 2021 11:12 pm
#89738
As part of my intake refresh earlier this spring I put in a new motorad 180f/83c thermostat (drilled a bleed hole in it too) and the bypass seal was already fairly new. The thermostat that was in there was a 170f/75c wahler. The past several years I've had the car (86.5 us) the temp always stayed pretty close to the first white line (marked 170 on some cars). Water bridge temps were normally in the mid to upper 180s as measured with an infrared temp gun. I could sit in traffic on a 90+ degree day and the temp would never go above half on the gauge.
With the motorad 83c stat the gauge was hovering from about half on the gauge to the upper white line. I'd notice it oscillating between half and the upper line (marked 210 on some cars) every minute or so even at steady state 50mph driving. Water bridge temps were hovering around 215f when at the upper white mark. Then one day sitting in a drive through in ~80f weather with the a/c on the temp got about a needles width above the upper white mark. When pulling back out onto the road with moderate throttle the car pinged some, so backed off the throttle. Once moving it cooled back down to just around the upper white mark again.
At this point I wondered if that motorad stat wasn't working well, so I installed a new wahler 83c stat. It hasn't gotten quite as hot as it did when it pinged, but it still is hovering from halfway to the upper mark. Temps on the water bridge around 215-220. I put on a new fan clutch because the old one definitely felt like it had leaked some fluid over the years, but that didn't change anything with the temps. Driving 70mph down the road even the temp was still sitting pretty high.
Today I decided to put the old 75c wahler stat back in to make sure I'm not going crazy here. Sure enough the needle won't quite leave the first white line now. Water bridge temps are sitting in the mid to upper 180s. Even letting it idle in the driveway (mid 90s ambient) with the a/c on the highest water bridge temp I could see was 192. So that tells me that something is up with both the 83c wahler and motorad stats as it seems like the car's cooling system has plenty of capacity to dissipate heat otherwise.
I threw both of the 83c stats in a pot of water on the stove. The motorrad cracks open right at 180f and was fully open around 200f. The wahler waited until 182 or so to crack open and was also fully open right around 200f. I had already put the 75c stat back in the car at this point, so I wasn't able to compare the amount the rear section moved to seal off the bypass.
All I can think is that the 83c stats aren't sealing off the bypass somehow. Again that seal is new and doesn't seem to be a problem with the old 75c wahler. I'd expect to see the water temp running closer to the 200f that the stat is fully opened at then and not getting up to 230. This makes me wonder if that's the problem with my tan 86.5 project car overheating too.
Anyone have any thoughts or notice anything weird with new thermostats lately?
Some pics:
New 83c wahler top, old (dated "09 03") 75c wahler bottom. Didn't get a picture of the back, but the bypass sealing disk looked to be the same size on both.
New 83c wahler left and new 83c motorad right. Both fully open, water temp between 200 and 210f.
Bypass seal:
Some pics:
Bypass seal:
-Matt
-84 928S auto - parts car
