Its been so long since I've seen a stock front caliper on a 928 my memory has gotten the best of me. I've got the Brembo GT caliper setup and a set of Roger's aftermarket stainless brake lines. I'm not sure how to clock the fitting on the caliper, and I the brake hose port on the Brembo calipers are in a different location.
Does anyone have pics of the aftermarket lines installed on a GTS or S4?
