- Thu Jul 01, 2021 8:42 pm
#89071
I just finished a t-belt/wp job on an 85S that's on its way via carrier to its owner's Florida retirement venue.
It's going to need a retension after the usual interval. (And there's a non-trivial 'todo' list too. I hadn't seen this one since 2008; it was booked for a belt and A/C in a narrow calendar space between two more-extensive projects. So, no time to chase non-trivial items. And it pretty much needs everything except what I just touched.)
Anyone got references for a 928-savvy shop in the Fort Meyers area?
My 928 Inspection Guide
