Not sure what a "Coni" is. But you have "Sachs" dampers.
The front wheels are the wrong offset. So, assuming the wheel bearing dust cap is fully seated then your options are:
- determine if there's any gap between the end of the spindle and the dust cap so that you can grind down the cap (as per smiffypr above)
- use a wheel spacer if you've enough wheel stud length for it. Looks like all you need is a 3-5mm spacer.
My 928 Inspection Guide
