I’ve done every other rubber bit in the front and rear suspension. I’m waiting on rotor hats so time to pull the suspension for the umpteenth time..
New bits
Old bits
Most hated substance on the planet
New favorite tool of the week. I bought a pair of these about a year ago to help position exhaust. I like the threaded part so you can use it like a floor version of the shop stand.
They are RV levelers. Not to take the place of jack stands but unbelievably frickin handy for tons of stuff. In this case holding the upper control arm parallel to the ground so you can get the strut assembly out easier.
to drop the front shock out, I unbolt the ball joint from the lower control arm, loosen the rear lower control arm bolts but do not remove. Then I remove the front bolts for the lower control arm. ( I do not remove the bolts holding the bracket for the front control arm bolts) Lower control arm pulls down out of the way, shock drops out easy peasy.
#83055
Sterling,
LOVE the support jack for the hub. I've got an A8 and the GTS to do suspension work on over the next year. Just ordered a pair. Thanks for the suggestion.
Gary :jumper:
Gary Knox wrote: Sun May 30, 2021 3:51 pm Sterling,
Gary :jumper:
Works like a charm.
This is also another favorite
Also just as a note the new front strut bushing is 10mm taller than my 30 year old one.
#83108
Hmmm... That's interesting. Never thought about that one.
Sazerac wrote: Mon May 31, 2021 2:18 am Hmmm... That's interesting. Never thought about that one.
https://openroad.site/viewtopic.php?f=25&t=2023
maddog2020 liked this
#83757
Sterling,
Can you post the height of the new strut mount bearing? That would help all of us know how much ours has collapsed whenever we start working on refurbishing the front suspension.
Thanks,
Gary
Gary Knox wrote: Thu Jun 03, 2021 4:06 pm Sterling,
I already did: https://openroad.site/viewtopic.php?f=25&t=2023
#83922
worf wrote: Fri Jun 04, 2021 2:22 am
David,
The only number I saw on this post regarding the strut mount is the 'the new one is 10mm taller'.
Being relatively new to this site, I was not aware that the light grey print in your post was a link. As I peruse that post, it looks like the new ones are 80 mm 'tall' - correct?
Thanks,
Gary
@Gary Knox
Correct: the new ones I measured were about 80mm thick measured from the point where the spring plate captures the end of the coil.
@maddog2020 It will be interesting to see if the new mounts have any initial “settle” and the magnitude if any.
Cleaning up after replacing the front strut bushings and finding you left out one of the washers that goes between the bushings.   Don’t know which side I left off.
:banghead:
Cell phones come in so handy these days...
This one has the washer
This one doesn’t
I’m down to a strut removal in under 5 minutes.... :order:
BTDT ate the labor. Sucks. But, I guarantee you’ll never do it again!
Helpful hint from a British Car forum: Q: My car […]
:thumbup: :rockon: :burnout:
