By The Fat Man
#83491
Gentlemen, and whatever ladies have the poor taste to be present,
I have recently learned that the Bowden cable O-ring for 1983-86 A28.** transmissions is NLA. Or at least I can't find it from the usual suspects.
Soo...I have dug out my spare and got some dimensions.
999 701 664 40: 1983-86
Mercedes 0119972248?
19.05mm OD
14.28mm ID
2.33mm cross section
Metric 2.4x14.6 O-Ring may work: 19.40mm OD, 14.60mm ID, 2.4mm cross section
19.05mm = 0.75" = 3/4"
14.3mm = 0.5629" = 9/16"
2.3mm = 0.0905" < 0.0938" = 3/32"
SAE #113 O-Ring may work: 3/4" OD, 9/16" ID, 3/32" cross section
If and when I figure out how to post photos here, I will do so.
Bertrand Daoust liked this
By The Fat Man
#83492
OK...surprised that worked. I will now attempt to add more photos.
By The Fat Man
#83495
By The Fat Man
#84191
Sweet! Then this is a non-issue. Thanks!
:thumbup: :rockon: :burnout:
