Sometimes shifts are smooth and firm, sometimes it slams the :cussing: out of it. Downshifts, 3 to 4, are harsh sometimes too.
No pattern, no consistency.
What I've done:
Replaced the vacuum line that runs from engine to regulator
Checked the vacuum while running, tee'd in a mityvac, normal.
Changed the fluid/filter.
Adjusted the regulator.
Now it's starting to get hesitant on the upshifts.
Low RPM shifts and WOT shifts are fine, normal driving shifts suck.
By Schocki
#77940
Check the vacuum regulator itself. You can replace it with a new upgraded MB unit. Roger should have them.
Modulator holds a vacuum well, beyond that I don't know.
I'll look at it. Thanks.
Just an update on this hot start problem. Since […]
