By WyattsRide
#69626
Setting my last intake in place, I somehow ripped the paper gasket. Am I SOL for now, until I get another? Or can I smear some peanut butter or something better on it and keep going? (Don't judge me because I used paper gaskets.)
Thanks for any advise
#69628
You could use a bit of Victor Reinz on that spot and hope it seals it up. Ideal? Nope, doable? Possible. FWIW, I use the paper gaskets and have had no issue doing so.
By WyattsRide
#69634
SeanR wrote: Sun Mar 28, 2021 5:00 pm You could use a bit of Victor Reinz on that spot and hope it seals it up. Ideal? Nope, doable? Possible. FWIW, I use the paper gaskets and have had no issue doing so.
Where can I get Victor Reinz? Basic Auto parts store or only on-line? How about 3m black gasket sealant?
Bertrand Daoust wrote: Sun Mar 28, 2021 5:03 pm Is it completly rip in two?
If it is, I would change it.
But that's me!
Unfortunately it's completely ripped. :bigcry:
#69638
Like Sean said, ideal no but you can try to glue it with some sealant.
If the finish is clean and smooth, worth a try maybe...
At least you caught it before you buttoned up.
I chased a lean condition for months before I found a damaged gasket on a smoke test.
I’m sure sealant above would hold or some drei bond, but will you agonize knowing it’s there and not perfect :)
By WyattsRide
#69649
Crumpler wrote:At least you caught it before you buttoned up.
I was really making progress today too! I could have put in the injectors and fuel rails next. Looks like I'm just going to order a couple new gaskets. It's the best option for sure. :surrender:
Rick I have the sealant from Roger and you can borrow a dab. I would get the new paper gasket though. I would not trust it.
#69693
WyattsRide wrote: Sun Mar 28, 2021 5:19 pm
But that's me!
Roger is always the answer.
By WyattsRide
#69794
Yes, he is! Already spoke to Roger and it's being delivered to me. Roger is hand delivering new gaskets to me in person. What customer service!!
