#69099
So, I am removing the upper a arms to put in new shocks. In the process of removing the 22mm nuts on the inside of the fender, I noticed only one washer per driver/passenger side. I was expecting a washer for each 22mm nut. Is this correct?
#69214
excellent. thanks for the confirmation.
