#67146
I’ve been thinking about the criticality of TB tension during engine operation and figured I’d post a few thoughts for discussion. Conclusion: like everything in engineering, it’s a balance between multiple competing factors.
1) During operation, the tension in the belt changes in the various segments. Segment 1-2 has the greatest tension as it has to drive the entire system.
2) After the oil pump (2) the tension (T 2-3) is reduced by the amount of force (torque) required to drive the oil pump (OP). Then reduced again for the left cam (3), water pump (4 - WP) and right cam (5)
3) The tension in 5 – 6 – 1 segment is basically the same and is where the tension is lowest.
4) Because the torque required to drive the cams (3 & 5) changes during operation due to cam loading, the belt tension is constantly fluctuating throughout the TB, even at a constant RPM.
5) Assuming items like the OP and WP require more force to drive at increased RPM, belt tension also changes with RPM.
6) Why Tension is critical?
a. Too much tension:
i. Increased static tension stress in TB. Once operating, the variations in tension based on belt location, RPM, etc. increase fatigue in belt as the belt tension cycles about a higher baseline tension.
ii. Increased loading on the sprockets causing premature wear on them and the belt.
iii. Increased load on rotating part bearings and seals
iv. Any other?
b. Too little tension:
i. Reduced belt resonant frequency leading to increased displacement at resonance.
ii. Possible belt teeth slapping sprocket teeth?
iii. Any other?
c. Belt resonance.
i. The belt, like a guitar string has a resonant frequency (Fn) which is a function of the length of the belt segment and the tension – longer length segment and lower tension both equate to lower Fn.
ii. A lower Fn means that when the belt does vibrate (resonate), the amount it moves (displaces) increases.
iii. The Fn of the TB is within the 928 RPM range, meaning it will resonate. I’ve seen a video showing the belt resonate as the engine ran up in RPM.
iv. Any other?
7) 928 Engine TB specifics
a. The 6 – 5 and 5 – 4 TB segments are some of the longer segments with the lowest tension. Thus, the Fn of these segments would be the lowest and would have the greatest displacement.
b. I’m thinking Porsche added the roller there knowing this, thus preventing these belt segments from contacting the tensioner pivot shaft (or each other).
c. I’ve seen pictures of the aftermarket tensioner which didn’t have the roller there. Could this be a potential problem, having unrestricted motion between the 2 adjacent belt segments? Perhaps it has been tested?
Following. Also, too little tension could result in tooth jumping on cam sprockets, causing valve contact with pistons
#67187
linderpat wrote: Thu Mar 18, 2021 1:56 pm Following. Also, too little tension could result in tooth jumping on cam sprockets, causing valve contact with pistons
I suppose it's possible, but you would have to have ~27 teeth all skip at the same time - the belt would have to be sloppy loose to do that. As I recall, even with the tensioner fully retracted, the belt is pretty snug and wouldn't really allow that to occur. Has someone experienced this in the past (tooth skipping)?
#67190
Geza-aka-Zombo wrote: Thu Mar 18, 2021 3:13 pm
Yep, several times with failed factory tensioner bits.
#67192
With broken bits, I can see that happening.
I'm contemplating a longer post for later. In the meantime:
Geza-aka-Zombo wrote: Thu Mar 18, 2021 3:13 pm As I recall, even with the tensioner fully retracted, the belt is pretty snug and wouldn't really allow that to occur. Has someone experienced this in the past (tooth skipping)?
SeanR wrote: Thu Mar 18, 2021 3:34 pm Yep, several times with failed factory tensioner bits.
I have had a belt skip a tooth on a brand-new-everthing on-a-stand motor. It can happen if you've forgotten to put any pressure on the tensioner bolt. :banghead:
But, I'd wager that is is harder on anything without GT (or "lob-ier") cams. Both sides of the GT motor's like to jump due to lobe pressure. So what might cause a GT to skip a tooth might do nothing on an S4/S3 etc.
Thanks gentlemen
