- Sat Mar 06, 2021 2:20 pm
#64746
Ever wondered what your abs rings look like? Usually they are black coated with brake dust and other grime. The abs sensor reads the teeth as they spin around past the sensor. Over the years I’ve seen abs issues that some owners have lived with for years. Before going down the expensive rabbit hole of buying new sensors, I’d recommend removing the sensors and getting all of the metal shavings off of them 1st. The abs rings are steel, and when coated with gunk and grime may not be so easy for the sensor to read.
I’m removing my abs rings from the 928 hub to put them on billet 944 hubs so I can have better offset options and pull the wheels inboard. Here are some pics of the hubs and my removal process. I’ve already cleaned the hubs and abs rings up quite a bit to pull them off.
I’ll upload a pic of them after they have soaked a bit.
