By Shifted - Sat Nov 28, 2020 9:07 pm
#38013
captainOCD, Hey_Allen liked this
Shifted wrote: ↑Fri Dec 04, 2020 7:48 am With a remote cut off switch, it would be really easy to wire in a whole car fuse.After the picture thread about the fire, I found a large fuse holder with intent to install it on my car.
... not anything inherently wrong with the 928's design, vehicle age included.
Shifted wrote: ↑Fri Dec 04, 2020 7:48 am I remember reading that thread thoroughly, and looking at all of the photos. To be honest, I don't think the cause was as innocent and universally applicable as the business owner made it out to be. My personal opinion is that it was due to negligence of the shop, not anything inherently wrong with the 928's design, vehicle age included.I posted to that thread with some observations of how the front main harness is often misrouted.
Hey_Allen wrote: ↑Fri Dec 04, 2020 11:54 am That said, I have found degraded wiring on my car, with insulation just dissolving or cracked and crumbling off, so I'm not going to totaly lay the blame on the shop.This too. I have noticed over the last 5-ish years that all of the wiring harness on 928s brought to me are very brittle. I take extreme care to perturb them only as much as needed and every single time I see cracked insulation on a power lead I deal with it.
Shifted wrote: ↑Fri Dec 04, 2020 7:48 am How many others like this have you heard of vis-a-vis failed fuel line fires?I am of the opinion that the majority of fuel fires are the result of poor work(*) just prior to the fire. Or, in other words, 100% of fuel fires after fuel system related work are the result of poor work. I believe that there have been fuel fires due to three-decade old fuel lines releasing fuel however, I do not recall a credible story being posted to the other site.
Shifted wrote: ↑Fri Dec 04, 2020 12:04 pm .............. I pointed out that ANL fuses are the right type for this application and provided technical references to back it up, ......... Just something to consider before you commit to a fuse type.Can you please expand what you mean without going too technical?
Shifted wrote: ↑Fri Dec 04, 2020 7:48 am With a remote cut off switch, it would be really easy to wire in a whole car fuse.Yep.
Ronin-951;9324668 wrote:Just Today, pretty happy with yesterday, tomorrow ... not worth the wait.
drfous;9486589 wrote:Rule # 159 - There are no promised benefits.
Streck-Fu wrote: That's a particularly judgmental and dismissive statement.
SeanR wrote: ↑Mon Dec 14, 2020 5:54 pm I'll be odd man out here. I abhor those things and have removed a ton of them from cars. Got a battery drain? Fix it. Want to disconnect the battery? Take the 13mm bolt or wing nut off and put a rag/cardboard on the end of the neg cable.Do they cause issues?
My '88 can sit there for a couple of months and will still crank over fine.
Shifted wrote: ↑Mon Dec 14, 2020 7:32 pm Whoa...bad day? lol
It's not going to fail from bumps. It's not going to short or ground out. Nothing is exposed, and the wire quality far exceeds the OEM ground strap. The switch will eventually wear out. In a decade or three. And when/if it does, it's very easy to bypass or replace.
To each their own, but I wouldn't rag on someone else doing something that works for them.
SeanR wrote: ↑Mon Dec 14, 2020 5:54 pm I'll be odd man out here. I abhor those things and have removed a ton of them from cars. Got a battery drain? Fix it. Want to disconnect the battery? Take the 13mm bolt or wing nut off and put a rag/cardboard on the end of the neg cable.I agree completely with this. I had a cut off on my Boxster because you cannot disconnect easily like the 928. I like the options here, but only for my 997, for the same reason as the Boxster.
