By ChrisZ
#327689
Well this was interesting. Last time I drove the 86.5 928S I noticed the brakes were a bit soft. Odd, so noted it and parked it and with a lot of pressure I felt the pedal sinking. Except it's 30 degrees outside so the fluid (1 year old) is not bad.
Fired it up this afternoon and took it around the block. Brakes went from good to gone in seconds, fortunately I was driving slow with my hand on the hand brake, but the pedal went to the floor and there was nothing slowing it down but the emergency brake. Turned around, drove it back home slowly, had to use the E-brake going down my driveway to stop it.
Not good at all. No brake warning light, either it's burned out or the switches are bad but my guess is it's the master cylinder. Checked the fluid reservoir, up to normal levels, no leaks under the car.
Car is offline till spring (pulling the battery so no one drives it by mistake); I have the 944S anyway so am good to go.
Any thoughts on replacing the master cylinder? Do the fenders need to come off? Engine come out? :-) Any issues bleeding the ABS system?
Thanks! Wild day...
Chris
The brake master cylinder is a straightforward(*) R&R. It's the clutch master that is "fun."
Problem is that new BMCs are either NLA or cost as much as college tuition (I forget which but the end result is the same.)
Mark offers rebuilt units. Make sure that the end of the booster's pushrod is shaped *identically* to the inverse shape of the rod receiver in the replacement BMC. There's a "smooth end " push rod and a "round with a tiny locating pin" push rod. And BMCs with an accommodation for the tiny pin and BMCs without. If you've got a pin on your rod and no accommodation, the pin has to go bye-bye.
You don't need to worry about the ABS.
* As straightforward as any R&R for a part that hasn't been touched in 40 years. You may need an inductive heater for the hardlines.
By ChrisZ
#343369
Ok, well after 5 months of going out weekly, pouring penetrating oil on the bolts and brake line to cylinder interface everything came off with pretty much ease. Helps to have 1/4 inch tools to get into the tight places and Snap-on won't snap :-)
Anyway cylinder is off, it has a round interface to the brake booster and the pin that presses on it is round. Time to get a new one, then the car can get back on the road. This one looks... Sad.
Just takes time to do....
hernanca liked this
#343813
Congratulations on that approach that allowed for easy removal!
Stan's frequent commentaries OTOS about brake master cylinders has largely created my set of prejudices about them, which have been subsequently confirmed by experiences in my old 928s and SAABs:
1.) Brake master cylinders are a wear item
2.) Strange brake behaviours are usually an early sign of BMC failure
I have also then followed Hacker's advice of rebuilding all sorts of hydraulics stuff at Whitepost (www.whitepost.com). So far so good. The only thing I don't like about them is the lousy black paint they use to repaint the cylinders. Your cylinder is quite sad looking though, so you may want to try rebuilding a nicer one.
By ChrisZ
#344133
Whelp home from SITM and going to ask Jeannie to get me a new cylinder. The old one looks like the seals just failed.
So I took a look at the reservoir. It is of course filthy on the outside, however washing it out is causing all sorts of rust and gunk and whatnot to come out. It's filthy on the inside as well, which is.... odd.
I may just replace that as well; any thoughts on cleaning it? Thought about just dropping the whole thing in carb dip, but worried that would wreck the plastic or whatever it is made of....
Not too good here, not too good.
ChrisZ wrote: Tue Jun 09, 2026 6:23 pm So I took a look at the reservoir. It is of course filthy on the outside, however washing it out is causing all sorts of rust and gunk and whatnot to come out. It's filthy on the inside as well, which is.... odd.
Use a 'soap' not anything acidic or caustic. I prefer D-Limonene-based cleaning products for 99% of 928 cleaning tasks.
Any non-foaming "citrus power" product will do. Or even a foamy one. I use P21S Citrus Total Car Wash concentrate diluted 1:1 or 2:1 with distilled water.
Get some plastic push nuts to seal the outlets. Fill the reservoir. Shake. Let it Sit. Shake. Tip it on its side. Let it sit. Shake. Sit...
You get it. Once the water/cleaning agent is black. Dump it. Lather rinse repeat until the res is clean.
Rinse several times with distilled water. Do a final rinse with alcohol.
There are baffles in the res, so it's a process to clean and *thoroughly* rinse it.
By ChrisZ
#344160
Ok, but this is not totally "unusual" I assume
ChrisZ wrote: Tue Jun 09, 2026 9:41 pm Ok, but this is not totally "unusual" I assume
The black shit in the reservoir is a mixture of iron and rust.
The reason it's in your reservoir is because the brake fluid in your 928 wasn't changed every two years.
Probably, before you bought it, it sat or ran around for 10 years with no brake fluid flush.
By ChrisZ
#345264
Quite possibly. Oh well as we like to say....
Good news, got the new brake master cylinder. Fired up the car to back it up in the driveway so I can pull tires and start a-bleeding and.....
Yeah, car doesn't move. Driver's rear wheel is locked. Great. Jacked it up, tire moves a small amount in either direction then is binding on something; my guess is the emergency brake is stuck.
*sigh* Back to the drawing board. Oh well at least I rebuilt my AC compressor on the 944S.....
By ChrisZ
#345310
So had some time today and pulled the rear wheel. I'm wondering: Was I Rip Van Winkle and it's been 20 years since I have driven this car, or 7 months?
Yes the wheel was locked, although with the emergency brake on it would not move and with it off, it moved a small amount (5 degrees or so). So with the power of Friendship, the fact that I put generous amounts of anti-seize on the screws, and an assist from Mr. M10 bolts in the damn puller holes the brake disc/drum came off.
Looks like the brake shoe secured itself to the brake drum hard enough that it finally pulled off the shoe. Maybe I heated the emergency brakes up a *tad* more than I thought when I did that emergency stop.
So adding "rebuild the emergency brakes with new springs and shoes". Again. Although it's probably been 9-10 years since I was last in there....
That said, I have a LOT more confidence in this new master cylinder. And I mean *new*, it still has the faint smell of burning money which is a symbol of a Genuine Porsche Part.....
By ChrisZ
#345361
Interesting chicken and egg problem, I can't move the 928 in the driveway to get clearance to work on the passenger side tires for bleeding the lines without a working parking brake so I'm stuck for a few weeks waiting for parts and other weekend projects.
I guess I could strap it to the Elec-trak, but I'm not sure those brakes can handle 4000 pounds of car either. Never dull.
Interesting chicken and egg problem, I can't move […]
While not really dialed in for the track, since I […]
16 valve and S4/GT strut bars are in stock. htt[…]
tow eye tap for the UK
have finally got the OK from the maker that they c[…]
