its what i would call a copy position sensor, Porsche call it a Potentiometer and clips onto the seat motors, and the seat movement cables go right through it into the motor.
plugs into the seat memory ecu so the ecu knows where the seat is, if a memory position is saved.
this one is for one of the up / down seat motors
Congratulations, Ed - that's great and very well presented!
^^^ My grill slats misalignment explained!!!
worf, linderpat liked this
just found a pair of Carl's rear tie down mounts.
did anybody ever make a spacer / sleeve so the 2 mounting points were not locked together ?
hernanca liked this
just had some fag lighter decals made, left to right:
decal
lighter with new decal stuck on
lighter with good factory emblem
lighter with fading factory emblem
lighter with factory emblem rubbed off
good enough for a concourse judges eye, without another one to compare it side by side ?
:drink:
By MAL_PA
#317443
h2pmr wrote: Sat Aug 23, 2025 8:26 am just had some fag lighter decals made
Very cool.
Where is this white line coming from? Does it present in real life, or is it just a camera 'illusion'?
MAL_PA wrote: Sat Aug 23, 2025 8:35 am
Very cool.
Thanks, the white on the lighter is reflection from the LED strip lights above me, pictured below with the lights off
white around the decal is the backing of the sticker so you can get a fingernail in to peel it off
MAL_PA liked this
One of my brothers works part time at a Tabacco store. Went to visit him today and I HAD to buy this $20 3-torch lighter! The base is a yellow glass, so you can see how much butane you have and it looks like beer. :burnout:
AirtekHVAC, MAL_PA liked this
AirtekHVAC wrote: Wed Oct 15, 2025 8:23 am Been a while since ive been on the site…bought this 83 last year- slowly bringing her back to life
Beautiful color - what is it!? I was going to guess Petrol Blue, but I think it would be darker.
Cr@p! Forgot a pic! Adding, lemme see here... Ah!:
By ladybug83
#322756
hernanca, JBT3 liked this
She's finally home*. I'm happy with my tweaks. Need to continue test driving. Already used it for "date night" with the wife.
Next steps at home include more experiments/test fits and putting things back on (rear spacers, rear bumpers, ...), then install the Robb Budd (Classic9) & Brian Wasinger (olmann) custom interior. :burnout:
Kind of liking the "no fog lights trim" look (Euro versions needed) - reminds me of Tass' race car mod (headlights in fog area). Needs to be refined, however. Front wheels are optional 944 7inch et52.3 wheels widened 1 inch to give 8inch et65 wheels with a dished look to match the rear 8inch S4 wheels. Polished and protected early metal grill slats. Keyhole is polished (need to repolish and protect). Brake duct inlet partially painted to match early 928 lines. Headlight washer delete is a stock Porsche part with same plastic nut underneath as nozzles (still needs paint). Color matched A.I.R. S-5 wing.
*Until I get all the "phase 2" (tuning) parts collected and ready.
Reppin' the mighty Scheissco brand at 3rd Coast for @Daniel5691 ! From L-R: Former Charlie Sheen GTS owner Chuck S, myself, 928 mechanic extraordinaire Sean R and 928 turned 911 owner Richard K.
N_Jay, hernanca, Bertrand Daoust and 2 others liked this
anybody know if any of these numbers are manufacturing dates ?
no other numbers on the belt anywhere
makes a nice change to find a set in the UK covered in dust and not rust
hernanca, XR4Tim liked this
picture from my friendly local OPC :beerchug:
I have it on good authority that Hemmings will only feature 928s in Amazon Green.
Gary Knox liked this
any use to you guys that make up wiring looms ?
rubber parts on the ABS / pad warning harness
i have a dozen, lack of heat and sunshine over here helps to keep them ok.
just the price of postage needed
h2pmr wrote: Wed Mar 25, 2026 4:24 pm any use to you guys that make up wiring looms ?
I only use new ones. Sorry.
no problem Dave
firewall harness grommet any use ?
although might me different as its RHD
^^^^ ...and thoroughly cleaned and inspected, correct?
Looks Great!
How many GT resonators might a 6.5 L stroker require? (my conclusion is actually three (3), based on my handy basic* area equivalents chart and other ponderings... )
(*it does not account for additional friction losses or pipe thickness.)
Exhaust mods done. Had a broken exhaust hanger and WTWIT (While They Were In There), had some changes made:
1. Swapped X pipe for an H-pipe & placed closer to motor.
2. Added O2 sensor/bung to H-pipe.
3. Put in Corsa Extreme mids (used, from SRT-8 Dodge Challenger).
4. RMB-->two 12 inch bullet resonators.
5. Modified Borla Tip for dual 2.5" (Part # 20243)
Hi Flow cats coming after tuning.
Different, quieter sound - Love it!
Skyhawk172, amdavid liked this
amdavid, hernanca, JBT3 liked this
Dang, wish I was there! (Daughter's wedding coming up....)
Camp 928 report:
5 16v Euro 5-speeds here. (4 pictured) Along with a variety of other vehicles.
  • 16
  • 17
  • 18
  • 19
Camp 928 report: 5 16v Euro 5-speeds here. (4 pic[…]
tow eye tap for the UK
have finally got the OK from the maker that they c[…]
Antique S2000
https://i.gyazo.com/9316731312e78d44dbc40f823c5c1[…]
Floor Mats
Well, what did you end up with? Back burned t[…]
