By ChrisZ - Mon Dec 29, 2025 4:43 pm
#327689
Well this was interesting. Last time I drove the 86.5 928S I noticed the brakes were a bit soft. Odd, so noted it and parked it and with a lot of pressure I felt the pedal sinking. Except it's 30 degrees outside so the fluid (1 year old) is not bad.
Fired it up this afternoon and took it around the block. Brakes went from good to gone in seconds, fortunately I was driving slow with my hand on the hand brake, but the pedal went to the floor and there was nothing slowing it down but the emergency brake. Turned around, drove it back home slowly, had to use the E-brake going down my driveway to stop it.
Not good at all. No brake warning light, either it's burned out or the switches are bad but my guess is it's the master cylinder. Checked the fluid reservoir, up to normal levels, no leaks under the car.
Car is offline till spring (pulling the battery so no one drives it by mistake); I have the 944S anyway so am good to go.
Any thoughts on replacing the master cylinder? Do the fenders need to come off? Engine come out? :-) Any issues bleeding the ABS system?
Thanks! Wild day...
Chris
Thanks! Wild day...
Chris
