Crumpler wrote: ↑Sat Oct 12, 2024 4:37 pm
The ball socket bushing is toast. I can move the release lever on and off freely. The release bearing is also has alot of play in it.
The release bearing/arm/PP interface has a lot of slop in it even new. Diagnosis not conclusive until it's on a bench. Or, IOWs, I haven't seen a t/o bearing so bad that it was obvious with the assembly installed.
I can’t slide the coupler back far enough to free the short drive shaft.
First problem is that the i-shaft is about 3/4" "pulled out" towards the rear. With both pinch bolts in place the clamp for the i-shaft-side of the tube is almost hitting the bolts for the guide tube.
Get the i-shaft nose pushed back into the pilot bearing. That'll give you a bit more room to work. But, not enough to get the assembly out ...
It looks like it’s hitting a TT bearing?
... because it does, indeed appear, that the TT bearing carrier has migrated forward. It would appear that you pulled the clamp tube forward to take the picture. It appears that the carrier is forward enough to occlude some of the drive shaft splines.
Do they migrate with time ?
Time-based degradation of the rubber around the perimeter of the bearing carrier and the bearing itself.
But yes, once the carriers migrate you get increase vibration. Increased vibration destroys the bearings and pieces fall off inside the TT. In some cases you can hear and feel the carriers sliding back and forth on the shaft during acceleration/deceleration.
And what is the move?
First, never, ever, pry on the clamps on the pinch tube. They are spot-welded and a pry bar can break the welds.
Hammer. Long tool (e.g. 1-foot long punch, or some 3/8" extensions plugged together, etc.)
More specifically, see if you can tap the bearing/carrier rearwards.
If there's no way to get the pinch clamp tube back far enough, then the next step is:
- remove the four upper bell housing bolts.
- remove transaxle mount bolts.
- detach e-brake cable from transaxle carrier or disconnect cable from handle in interior (to avoid stretching e-brake cable)
- slide TT/Transaxle assembly back an inch-ish (you'll run out of room before mounts will slip off of carrier)
- and you will likely have some problems getting the upper bell housing unstuck from the engine.
... and then see if you've got room.
With the i-shaft pushed back in, transaxle pushed aft, you might *just* have enough room to drop the clutch.
I don't know for certain; I've never had drop a clutch this way.
You will want to put a floor jack under the front of the oil pan before you pull back the TT assembly: the motor will droop forward considerably and if you have non-Porsche motor mounts (e.g. ford, anchor, volvo, etc.) they can be destroyed with prolonged 'droop' of the motor. You will also want to make sure nothing else gets hit/stretched/crimp if/when the motor droops forward.
My 928 Inspection Guide
