By Giddyupp - Sat Jul 06, 2024 11:14 am
#271002
Been working on this issue now for a month or so and have no clue as to where to look next.
1988 S4 Auto with 46,000 miles.
I had recently completed a top end refresh - car ran great except for a random (not every time) no hot start. It was suggested that I send the MAF and LH out for refurb. Whilst they were away, I decided to remove the electrical panel, replaced the relays and clean up all the contacts. I re-installed the rebuilt LH and MAF and now the car is not running well at all. It has a pretty low idle as well as a really weird popping/sucking sound that comes and goes whilst idling as well as soon as I shut off the ignition. See the attached video. It is also misfireing/stuttering once it gets on the freeway. Speedtoys came over yesterday with his parts car and we switched over both the MAF and LH - neither of which made any difference. My MAF and LH worked just fine when installed on his car.
Everything new as follows
LH
MAF - Also replaced the 5 Pin connector
TPS
Temp2 - also a new connector
Idle Control Valve - not replaced but tested good with a 9V battery.
All New Gaskets on top end
Spark Plugs & Wires
Fuel Dampers and Regulator - only 5 years old and all hold vacuum
Would love to hear everyone's thoughts on the weird noise. Any Ideas ?
LH
TPS
Spark Plugs & Wires
