I left my desk job a few months ago and started fixing cars out of my garage. Since I don't have any social media accounts, I thought I'd start a thread here to chronicle some of the more interesting things I work on.
One of the first cars to come through was this 1994 Alfa Romeo 164 LS.
My friend bought it sight-unseen with the seller noting that it doesn't rev above 2,000 RPM. He had the car shipped directly to my garage. When it arrived, it would barely run, much less get to 2,000 RPM.
I found a bunch of electrical connectors for things like the airflow meter, crank sensor, and fuel injectors were missing the metal clips that keep them engaged. There were no gaskets under the intake runners, the rubber boots connecting the intake runners to the plenum were all cracked and falling apart. The ground strap for the throttle body was not bolted to the throttle body, but was instead taped to another wire that was screwed into the plastic coolant reservoir at the other end. :banghead:
I did a compression test to get an idea of the condition of the engine, and found that the front bank of cylinders was all at around 50 psi. The rear bank was all around 170 psi.
I pulled the timing covers and found the carcass of a snake wrapped around the rear intake cam gear, and the front exhaust cam gear was one tooth out of time. I'm guessing the snake got up in there and didn't survive the next engine startup. He almost took the valves out with him. Resetting the timing, I got good compression on all cylinders, so we got out of it with no valve damage.
New timing belt, new clips on the electrical connectors, intake gaskets and runner boots, air filter, exhaust gaskets, oil pressure sensor, rear brakes, a battery, and a sunroof seal, and it ran like a champ. The car came with a binder full of receipts for maintenance, and the prior two owners had spent a combined $106k in maintenance and repairs on this car, including a $10k engine rebuild about 30k miles ago.
NSXguy, Scott at Team Harco, User2 and 2 others liked this
Currently, I'm working on this beautiful 1987 Mercedes-Benz 560SEL. It's getting front wheel bearings, a rear main seal, transmission front pump seal, steering box reseal, and an adjustment to the hydropneumatic self-leveling suspension, since the rear was sitting low when it came in. This should keep me busy for a while.
User2 liked this
Another one of the first cars to come in was this 2002 Mercedes S600.
My tailor bought it from an auction in Florida and had it delivered to another shop, who told him that it had a massive oil leak. They diagnosed it as a leaking oil cooler (common problem on this engine), and told him that they would not be able to do the repair. He had it towed over to me, and I drove it into the garage where it left a massive puddle of oil on the floor. The oil cooler sits in the V of the engine, and both cylinder heads have to come off to get it out. In all, it was not a difficult repair, just very time consuming. The car had 66k miles on it, and the spark plugs looked to be original, so I replaced all 24 of them during the repair.
User2, JRMaroon liked this
Very cool @XR4Tim!
I know you were also thinking of some retail operation as well, did you ever get that launched?
fpena944 wrote: Sun Mar 24, 2024 4:14 pm Very cool @XR4Tim!
I got a vendor's license and have been selling Alfa parts, but only through word-of-mouth. I don't have any e-commerce stuff setup at this time.
XR4Tim wrote: Sun Mar 24, 2024 5:34 pm
If you ever need help setting up a digital presence and promoting it let me know.
fpena944 wrote: Sun Mar 24, 2024 8:11 pm
I definitely will!
This 4Runner was purchased in a barely-running condition and trailered over to me. The seller claimed to not know anything about what was wrong with it. It was running very rich and not firing on all cylinders.
I found that the intake plenum was missing a couple of bolts, the spark plugs were finger tight, and the plugs on the left side of the engine were a different brand than those on the right side. The air filter was new, but the MAF and throttle body were both very dirty. The oil looked clean, but smelled like gas. The valve covers were both leaking badly because the bolts were loose. There were remnants of mud in the engine bay up to the hood. I think someone submerged the engine and started to try and fix it, but gave up and hastily put it back together.
Compression on all cylinders was good, so I set about fixing the other stuff.
The timing belt was in bad shape, so it got all new belts, new plugs, ignition coil boots, a MAF, valve cover gaskets, and an oil pan gasket. After all that, it ran better but had a cylinder 3 misfire. The plug was completely dry because the injector was not firing. Hoping to get away with replacing just one injector, I pulled the right fuel rail, and saw that the #1 injector came out, but left its tip in the intake. I fished the tip out and replaced the #1 and #3 injectors. Now it had misfires on cylinders 1 and 3. It turns out that all of the other injectors were performing so poorly that the ECM was compensating with extra fuel, which was making the new injectors dump way too much into cylinders 1 and 3.
When I pulled the left bank of injectors out, they were all missing their tips (and corresponding bottom o-rings). Someone had broken them pulling them out, and then put them back in without their tips. :kickbutt:
After replacing the rest of the injectors it ran perfectly.
SeanR wrote: Mon Mar 25, 2024 10:21 pm This is how things start. Then people want you to work on their stuff. Then you start doing it to make a living............
Exactly what happened. I had too many friends asking me to work on stuff for me to possibly get it done in my spare time. Plus I hated my day job anyway.
SeanR, lupo.sk liked this
XR4Tim wrote: Mon Mar 25, 2024 10:29 pm
This is how my dad started his business.
He would always fix cars on the side when in the Army but when he was nearing retirement he figured it could progress into a business.
Eventually got a shop with 8 bays and ran a pretty successful outfit for 23+ years. Sold it to move closer to us and truly retire. Shop still in business 5 years later.
So yeah, this could definitely turn into a way to make a living!
XR4Tim, SeanR liked this
New project was dropped off today.
This 900 Turbo suffered from a fractured transmission case. The owner at that time pulled the engine & transmission out and left it like that for the last 13 years. I've sourced a replacement low-mile transmission and will be going through the motor before putting them back in. I'm not looking forward to trying to figure out what fasteners go where, and how many are missing.
TheDeckMan liked this
This M6 is another one of my tailor's cars.
He drove it to work one day and it wouldn't start when he tried to leave. I confirmed that it had good battery voltage, and that full battery power was making it to the engine bay, but it would just click when the Start button was pressed, so he had it towed to me.
The starter is located under the intake, like on a V8 Cayenne, only BMW decided that it should be bolted in from the back for some reason. The official procedure is to remove the exhaust & driveshaft, and lower the transmission to access the starter bolts on top. I opted to leave the starter nose attached to the bellhousing, and remove & replace the gears, motor, and solenoid from up top.
Unfortunately, after doing that, the car still wouldn't start. I measured everything I could think of, but concluded that the replacement starter was bad. A bench test after pulling it back out confirmed it, so we ordered another starter.
I bench tested the second replacement starter when it arrived, and it would engage the bendix, and the starter motor would spin, but it wouldn't turn the pinion gear. For the third starter, we went for a different brand.
The OE starter is made by Valeo, and is backordered through them and through BMW (plus it's $1,200 from BMW even if they could get it). I found a Remy remanufactured starter for about $200, and have had good luck with that brand before, so ordered it. I installed it today, and it worked flawlessly. What a pain, but now I can replace these starters pretty quickly!
During the process, I also noticed a pretty big oil leak from one of the electric oil pumps. It just took a $14 seal (and $150+ of oil) to fix.
XR4Tim wrote: Mon Apr 29, 2024 7:40 pm This M6 is another one of my tailor's cars.
Every time my father and I work on one of my vehicles, he always asks why the Germans make it so difficult for mechanics to do maintenance. Who puts these bolts in?!?
We had to change out one of the upper control arms on the Cayenne and had the same issue with bolts pointing in the wrong direction. Thankfully we found a workaround but a challenge for no reason.
We've done the starter on the Cayenne also and it was unnecessarily complicated. I can swap out the one in my 996 in no time but with the Cayenne it requires disassembling the entire upper half of the engine!
Nice car that M6 is, I'm sure the owner is happy to see it back on the road!
Interesting twist: He texted me saying that the M6 wouldn't start and is back to just a single click when the Start button was pressed. He lives in an apartment in downtown Cleveland and the car was in the building's parking garage.
I put together all of the tools needed to get to the starter and went out there to figure it out. Everything looked correct, nothing was loose. My wife suggested checking the positive cable, and I had already verified that there were 12.6 volts present at the starter, but when I checked resistance, there were almost 2 ohms between the jump terminal in the engine bay and the starter, meaning the starter was only getting about 6 amps. I checked the cable from the jump terminal to the engine harness, and it was good. There is a terminal where that cable attaches to the engine harness, and almost all of the resistance was isolated to that piece. I pulled it out and bolted the jump terminal cable directly to the positive cable within the engine harness, and the starter cranked over just fine.
Here is the offending piece:
How this piece can fail is beyond me. Especially since I checked resistance when I first replaced the starter. It looks like just a stud that goes right through a plastic housing.
BMW's diagrams do not show this part. There is a BMW part number on it but if you Google the part number, there are zero results. Apparently it's only sold as part of the $1,400 engine harness. I told the customer that I could make something that would work, or buy a used engine harness, and he opted for getting a used harness and just swapping the part out.
fpena944 liked this
