By David993S
#25328
-cover the car (optional)
Cheers.
One of the few advantages of living in CA, even in the north (of CA)............no winterizing necessary. I will say spring is probably a bit more special there. Thanks for sharing, good info.
By NCporsche
#25352
I skip some of the OPs steps but always inflate tires to 50psi. Running Pirelli P6000.
Thanks for reminder, need to get car cover cleaned.
By NCporsche
#25361
JimV8 wrote: Wed Oct 14, 2020 12:43 pm Brakes calipers should be cleaned and sliders lubed too.
Why not wait until Spring and flush the brake fluid at the same time?
By JimV8
#25414
NCporsche wrote: Wed Oct 14, 2020 12:50 pm
Better I think to put it away up clean, and removes the urge come Spring to go for that first drive before doing those essentials.
My winterizing procedure:
- fill with gas and fuel stabilizer
- wash
- exterior detail as required: clay, polish, wax depending upon factors
- interior detail. Every other year seats get removed for thorough cleaning, conditioning. Makes it easier to vacuum too.
- on stands
- oil / filter change
- wheels removed, cleaned inside and out, waxed
- brake calipers cleaned on all sides and treated with a coat of CorrosionX
- brake fluid flush
- any other scheduled maintenance (i.e. plugs, belts, etc.)
- wheels back on, air up to 44 PSI or sidewall max inflation whichever is less.
- battery tender
- car cover
And then they sit until Spring.
By AKSteve
#25533
I'm going to parking my 991 turbo cabriolet over winter for the first time year instead of putting snow tires on and driving it year round. I change the oil in my 911's every spring. So is it really any worse to let the car sit until the spring compared to driving it with the same oil until the spring?
AKSteve wrote: Thu Oct 15, 2020 2:58 am So is it really any worse to let the car sit until the spring compared to driving it with the same oil until the spring?
I do it in the fall so that on the first day after salt/brine is washed from the roads I can *drive* instead of having to change my oil.
