NSXguy wrote: ↑Sun May 21, 2023 11:45 am Something has changed, as I can't see any images in this thread...even the ones I've posted (???)Look at this thread:
Scott at Team Harco wrote: ↑Wed Jun 21, 2023 2:43 pm Can you find a Reliant Robin body kit for that thing? Might improve its stability...
NSXguy wrote: ↑Wed Aug 23, 2023 9:20 pm Well we finally answered the question MANY have asked us, how fast does that little microvan go?Try dropping a deuce and doing another run. Maybe you'll hit 75!
We took it on the freeway (something we generally avoid) going Eastbound (so at least not against the wind) and logged a GPS honest 73mph.
The HH4 Actys (4WD Van) have been reported to only max out at under 70mph, so we've achieved a better number.
The HH3 vans (2WD) have a bit less weight but top speed is all about HP, so it's not surprising that we were able to (eventually) equal that mark.
i am not a traitor wrote: ↑Thu Aug 24, 2023 9:29 amI think if I tried another high-speed run, a dropped deuce would be a givenNSXguy wrote: ↑Wed Aug 23, 2023 9:20 pm Well we finally answered the question MANY have asked us, how fast does that little microvan go?Try dropping a deuce and doing another run. Maybe you'll hit 75!
Majestic Moose wrote: ↑Mon Oct 23, 2023 2:48 pm My mom and aunt have just bought a pair of Honda Street vans (1992 and 1993 I believe). They will be daily drivers believe it or not and I will be going through them top to bottom to make sure they are in good driving condition. I have found some good online resources for maintenance but do you have a good source for parts?Wow, how cool.......got pictures?
NSXguy wrote: ↑Mon May 01, 2023 6:47 pm After a looooong session in the garage, I have a couple updates.When we were behind you, on the way home, Wednesday, you 'accelerated' away from an intersection. Someone (not me), remarked that it sounds like a wet fart...
The straight-through exhaust was a bit too loud to live with, and since Supertrapp apparently doesn't sell the 5" SS end cap with the hole already drilled.....I decided to make one from a solid end cap.
Scott at Team Harco suggested I start with 3 holes with the possibility of adding more if it's too muffled, but after a spin around our sub we decided it was good just like that.
I prepped and painted the end cap high heat black, which came out great.
Majestic Moose wrote: ↑Mon Dec 04, 2023 8:51 am Ah good to hear I will get that too! The steering wheel does also clunk while going over rough terrain at low speeds like a gravel parking lot so that might help. Did you get a steering alignment after?It will need an alignment afterwards for sure, but so far I just did one in the garage with a tape measure...
Majestic Moose wrote: ↑Tue Dec 26, 2023 6:32 pm I did find that site but I got two full sets of decals from here:Sounds like some good progress so far, please share some pictures here as well.
https://www.etsy.com/listing/1101986904 ... rs=1&sts=1
The only one missing was the 660cc for the back window but I found it on ebay.
I did the timing belt on my aunt's van and her engine mount is pretty cracked so I will get that two part urethane like you did.
My mom is picking up her's from the paint shop tomorrow! She changed it to a brighter red.
maddog2020 wrote: ↑Thu Dec 28, 2023 10:54 am https://www.msn.com/en-us/autos/news/a- ... 961d&ei=37Honestly I don't see the big deal here. I doubt anyone has high expectations that these vehicles are going to fare well in a collision with an American-sized SUV.
NSXguy wrote: ↑Mon Mar 04, 2024 10:06 am Does anyone (Alex?) have a source for a Fuel Pump Relay for the Acty?P/N?
I ordered one through Hondapartsnow.com but they canceled it due to the part being no longer available...
NSXguy wrote: ↑Mon Mar 04, 2024 12:38 pm Part No.: 16760-692-003Last One
Relay Assy., Fuel Cut-Off (IWM-77001-4) (SHINDENGEN)
BTW, that exhaust temp sensor only lights a dash light so has no other function as far as I can tell.
Scott at Team Harco wrote: ↑Tue Mar 05, 2024 7:51 am maybe this oneThat LOOKS like the right relay, for sure...
https://www.ebay.com/p/1835038956
