By Crumpler - Tue Aug 08, 2023 5:12 pm
#228950
Hey guys.
I’m sitting in the pit.
Car gave out.
Drove to event.
First session I got several flickers on the central warning light. No specific lamps on cluster activated. Light went off but I went back to the pit.
All fluid levels good.
Trashed it around the pit, no warning lights. Oil pressure stayed fine. Vouching for coolant and oil, decided to try it again think it was some non-essential leftover connection like seat belt or brake pad sensor.
Went back out, couple good laps. Oil pressure stayed high on right and left sweepers.
Set up to pass a car saw a flicker, made a turn and noticed no steering. Looked down and car was off.
Restarted without issue, drove into pit. No central warning light or lamp.
This car is aftermarket ECU.
Odds of VEMS glitch killing car after central warning light flashed I assume unlikely.
What the hell would you look at first?
What capacity does car have to kill motor if not connected to ecu?
Alarm connection?
This is one of my lows in 928 ownership.
Car gave out.
Drove to event.
Alarm connection?
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
