By Strosek Ultra - Tue Jun 06, 2023 10:23 am
#219123
Strosek Ultra wrote: ↑Sun Jun 11, 2023 10:21 am Mr. Brown did not like the posting of these pictures.So what is that in there?
See Teutonic 928 hot rodding thread post # 212.
Åke
hessank wrote: ↑Mon Jun 12, 2023 4:57 pm What does the underside of this intake looks like, or company secret?As a Copycat Mr. Brown has designed this intake manifold to resemble ditto V8 manifolds found on BMW V8, Cayenne V8 and other engines from the 1990s.
An inquiring mind wants to know
maddog2020 wrote: ↑Sat Jun 17, 2023 9:29 pm https://tapped-performance.myshopify.co ... fold-black122mm bore spacing. Remember the 928 is a german car and everything is metric.
4.8" bore spacing on hemi big block that matches our bore spacing...
Strosek Ultra wrote: ↑Sun Jun 18, 2023 2:38 am3 thousands can be ported to match really easily. if the distance between the ports from one bank to the other is close this could be and easy fit especially considering how cheap it is.maddog2020 wrote: ↑Sat Jun 17, 2023 9:29 pm https://tapped-performance.myshopify.co ... fold-black122mm bore spacing. Remember the 928 is a german car and everything is metric.
Åke
Strosek Ultra wrote: ↑Sun Jul 02, 2023 6:31 am What I meant is that the 928 is built according to the metric system, therefore one should avoid translating measures and dimensions to the imperial system.I agree. But, good luck with that.
