By JBT3
#215288
@worf Is this your latest and greatest? I came across an old post on that other site that sounded like you were updating. http://www.928intl.com/repair/intake1b.pdf. Thanks.
Thanks all.
JT
1990 GT
‘compete?’
JBT3 liked this
By MFranke
#215516
Bertrand Daoust, JBT3 liked this
#215667
By JBT3
#215946
By JBT3
#218251
So intake is off and I’m working on removing the cam covers. Found this lovely sight when I went to remove the right side engine hook. :cussing: Going to try vice grips and a stubby screw driver to get it out and replace with a proper m8 hex head bolt.
By WyattsRide
#218286
JBT3 liked this
By JBT3
#218305
Thanks Rick! :beerchug: I must have misread the parts pdf. I saw quantity of 2 and thought someone had done a hack job on a bolt. I guess the two were for the left and fright engine hook. That’s a big time saver.
It’s a blind, by feel job.
JBT3 liked this
By Charlie
#218649
1985 Speedo Issues Part 2
