By jschiller
#216702
Recent posts in the Meme War - Non-Snowflake Edition in Dive Bar no longer show the images for me, only the image placeholder is displayed. This started on May 14, with only a few exceptions since then. I have tried both Brave and Chrome with the same result. I can't figure it out. :banghead:
Hmm, I can see them w/o issues. They are hosted on imgur, there might be a connection issue.
Try firefox, chrome & brave have the same engine so they are essentially the same.
jschiller wrote: Sun May 21, 2023 1:44 am Recent posts in the Meme War - Non-Snowflake Edition in Dive Bar no longer show the images for me, only the image placeholder is displayed. This started on May 14, with only a few exceptions since then. I have tried both Brave and Chrome with the same result. I can't figure it out. :banghead:
lupo.sk wrote: Sun May 21, 2023 5:06 am Hmm, I can see them w/o issues. They are hosted on imgur, there might be a connection issue.
I also don't see an issue and tried a couple of different devices and usernames.
I did a quick Google search and found that it is something that happens sometimes. Here is a site with some suggestions for troubleshooting:
https://www.digitbin.com/imgur-not-work ... er-chrome/
Let us know if any of it works.
By jschiller
#216776
I think the issue has been solved. I changed the DNS as suggested in the link above and the images are back. I'll update this thread if anything changes. Thanks Jefe :jumper:
jschiller wrote: Sun May 21, 2023 12:49 pm I think the issue has been solved. I changed the DNS as suggested in the link above and the images are back. I'll update this thread if anything changes. Thanks Jefe :jumper:
So glad it was a relatively simple solution! :rockon:
sunroof cover questions
928 quick questions thread
Sunroof t-shooting
I thought I'd post the text of the document so it […]
