I’ve never used red before. I traditionally use blue and torque to 218 foot pounds.
I had the pulley work loose during a dyno session today. Embarrassing, but luckily no damage to the treads on the crank.
Bad news is this is the huge 928 Motorsports pulley so I had to push the car off and pull the radiator to re-torque with red. Long day.
Well, not sure what was the problem. But, given “928 Motorsports”… that’d be my bet.
Washer backwards?
If not those then torque procedure perhaps?
I have a 3/4” snap-on y-beam torque wrench. I’ve never had a crank bolt come loose including the Twin-Screw.
One thing’s for certain: you’ll need to remember to heat that crank bolt before you attempt to remove it next time.
I don’t know. It does not give me a warm fuzzy that’s for sure. The pulley it supposed to be balanced, but honestly I never tested it. If it’s unbalanced you can’t see it with the naked eye.
The belt set up is reasonable, stock PS and alt to driver side and supercharger is a 6pk to passenger side.
Here’s the numbers for what it’s worth, before the fun began:
Roughly 425 bhp, 465 ft-lbs at the crank assuming 15% driveline loss.
Not shabby!
Nice torque curve too.
you shouldn't need loctite if you have a new bolt and torque to spec. I spun out the crank bolt on my fast revving stroker engine several times, and replaced with a new bolt and didn't have a problem again The longer supercharger pulley is going to amplify the stresses of the bolt and thread and a new bolt should have been used anyway. Did the kit specify loctite? what do the murf kits require?
#210338
Red is permanent - I don't think that was a good idea. Hopefully, the threads were not completely free of grease or oil.
Thanks Dave, I was pleased with the torque but I guess my hp goal was a little higher. I wanted to be able to say 400 hp at the wheels, but I will take it.
Sterling, Long story but I didn’t buy Carl’s kit, just the pulley. No sexual favors were required but you can imagine the conversation;)
I never saw his “directions”, I think you only got them if you bought the kit.
The bolt was new FWIW.
Geza, yeah I get it. That’s why I never used it before.
But, looking at the carnival yesterday it seemed the best way to get home. I have talked to people that have used it and say no issues, with heat of course.
Crumpler wrote: Thu Apr 13, 2023 2:22 pm Thanks Dave, I was pleased with the torque but I guess my hp goal was a little higher. I wanted to be able to say 400 hp at the wheels, but I will take it.
Horsepower sells cars. Torque wins races.
If you want more horsepower, you’ll have to figure out how to extend the torque plateau higher into the rev band. I don’t have a clue if your SC is the limitation or the intake or the throttle body. I’m assuming with that, that more air is required. But…
What’s the fuel-air ratio when the torque begins to drop.
Lol. Just don’t type that name again in this thread and we’re all good.
:thumbup: :rockon: :burnout:
