![popcorn :popcorn:](./images/smilies/popcorn.gif)
![eyepop :eyepop:](./images/smilies/Eye%20pop.gif)
I have the same set up from the x pipe back and mine does not even approach what you have going on there. That’s a testament to your headers or displacement or both.![]()
hernanca wrote: ↑Fri Apr 07, 2023 10:06 pm Love the underpants photo!My…. Sterling, what big pipes you have.![]()
