maddog2020 wrote: ↑Tue Dec 20, 2022 12:29 pm
I'm not sure how the direct injection setups are plumbed.
I haven’t cared about it (yet.) But DFI systems run at a Zillionty PSI. Pressure variation and pulse effects from (sequential) injection events is probably at “noise” level. If not, not too much code required to compensate for modeled pressure decrease at WOT. CPU cycles to burn baby…
My 928 Inspection Guide
