N_Jay wrote: ↑Wed Dec 07, 2022 8:31 am Does anyone use a vacume pump to change the oil in a 987.2 (or any other)?I use vacuum for bleeding brakes but not for the oil change. On some cars the drain plug could leave some oil behind but on the flat-six it's pretty much the lowest point of the engine so don't see a benefit except it might be cleaner with fewer potential spills.
In some cars people claim it can actually get more oil out.
Is there even a way?
Can a tube down the filler get to the bottom of the sump?
Now on the 981 I do wish there was easier access to the filter itself. I think my 996 is the easiest I've ever had but only the 981 the filter is squeezed between engine, transmission, and suspension so harder to get anything other than a filter socket in there.
