By worf - Mon Aug 22, 2022 6:22 pm
#167289
Once the cams, seals, back plates, and gears are installed the very next thing to do is to string the timing belt. So, I get all the 'stuff' installed on the front before doing cams.
Note that the cam caps on the intake side are installed 'upside down' - see WSM pages.
This is also a very good time to index the exhaust cams with the tools shown in the WSM. Once you've done that you have a zero reference for use of the PK'32vR if you want to make small changes later.
Think long and hard about how you'll go about it, think about what can go wrong. Once you've made up your mind, measure thrice. And best have twice the material you think you'll need.
A lot of it depends upon what you want it to look like when your done. Half-assed or factory-looking.
WyattsRide wrote: ↑Mon Aug 22, 2022 10:35 am Before setting the cam shafts, I think I need to put the WP on (with the pointer) and the dampener, to set the crank at 45. Is this correct?Yes. Crank must be at 45° BTDC.
WyattsRide wrote: ↑Mon Aug 22, 2022 10:35 am Then using the 9226/4 and 9226/3 gauges, to make sure the cam lobes are in the correct position.Yup. Pay attention to the WSM. You use those on different cylinders on each side. 1 and 6 IIRC.
WyattsRide wrote: ↑Mon Aug 22, 2022 10:35 am What can I do about the Firewall foil? Should I just clean it? Or is there something better that I can put over top? Any experience on doing this?If you attempt to clean it you'll likely end up with most of it on the floor. Either don't mess with it or go down the rabbit hole. DEI makes various products you can use on the insulation to replace the reflective material. Unless you want to remove *everything* from the firewall you'll want a thin flexible material that you can "work in" with the firewall accouterments loose.
WyattsRide wrote: ↑Mon Aug 22, 2022 10:35 am What about the Heat shields near the Motor Mounts? They have an insulation on them that is deteriorating. Something new for this? Any ideas?Bertrand covered you on that.
WyattsRide liked this
My 928 Inspection Guide
