By maddog2020 - Sat Sep 03, 2022 3:06 pm
Stepson wrote: ↑Fri Feb 17, 2023 1:19 pm You wouldn't want to be his neighbor when he starts it, although I believe he tries to be a good neighbor (not starting too early in the morning nor later at night). It is BEASTLY sounding. It rattles windows, makes small children cry, women smile and men kneel in homage to the very sound. :)Something like this?
Crumpler wrote: ↑Thu Feb 23, 2023 6:20 pm Well it’s a work of art that’s for sure.Cams and cam timing can change the sound drastically. Variable cam timing on the 1st video really made it interesting at full throttle. the second video has even hotter cams, and itb's. I also had too much dwell on the coils, so it sounded much more choppy (harley like). After I got the dwell dialed back, even with the hotter cams I could get a smooth even idle at 450 rpms. Letting it idle that low would make normal drivability difficult off idle, so I will set the warm idle @ 800 rpm.
I have the same set up from the x pipe back and mine does not even approach what you have going on there. That’s a testament to your headers or displacement or both.
worf wrote: ↑Wed Mar 08, 2023 9:58 pmA/C later?This was a test fit for my new fan shroud and I'll be installing the new condenser and radiator again after I get the FOE harness installed as well as compressor, belts and other front of the engine stuff. I'm really happy with the engine lift bracket with the integrated AOS bracket, and also got the fuel hose clamps integrated as well. There were a lot of version 1 brackets and stuff that I had the time to rework.
maddog2020 wrote: ↑Wed Mar 08, 2023 11:29 pm One of the big changes was going with a dual pass setrab oil cooler, to include its own fan shroud with cooling fans and flaps with the goal of being able to cool the oil when stopped or not moving fast enough to generate air flow.That will be interesting to see.
maddog2020 wrote: ↑Thu Apr 06, 2023 11:41 am headers are too large and bulky to work with any sort of belly pan.You gonna keep the metal hind-pan for the cats? Or ain’t got no cats?
maddog2020 wrote: ↑Thu Apr 06, 2023 4:05 pm no room for the hind pan either.Love the underpants photo!
hernanca wrote: ↑Fri Apr 07, 2023 10:06 pm Love the underpants photo!My…. Sterling, what big pipes you have.
