By Crumpler - Sun Jul 24, 2022 12:19 pm
#162379
Conversion from 86.5 (so S4 caliper and rotor set up) to GTS caliper and rotor set up on front. Rear will remain S4 set up for now. Good problem to have but with the SC, the current brakes don’t feel real “sufficient”.
18 inch wheels already on car, so clearance issue should be fine.
My initial research shows I need 322 diameter rotors, with 32mm thickness and height of 77 mm with hat height of 45mm.
Anybody think that’s wrong?
I’m using aftermarket stainless steel brake lines that i assume will convert in terms of length to new calipers ok.
My understanding is that OEM GTS was solid rotor and I’m looking for slotted/drilled. Anybody got a quick source? I was looking at the Mercedes 400 3654 20, which I think is a Zimmermann #000-421-30-12-07-M359 for the record. But I can’t find specs on height.
Any additional insight from my betters?
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
