- Sat May 21, 2022 4:44 am
#150717
Oil suppression kit for 32V 928 comprising of Valve cover oil separator plates for both cam covers set of four and the oil neck baffle and tool to remove nuts inside cam cover $265 shipped.
milrad wrote: ↑Thu Jul 14, 2022 10:45 pm Oh I know a guy with the initials GB that's going to be really mad at you!Regardless of your opinion of GB, there’s something not-right with copying his product right down to the washers under the bolts. That takes some gall.
maddog2020 wrote: ↑Fri Jul 15, 2022 9:37 am some people absolutely refuse to deal with GB's mood swings and rants. He has also moved into Carl's monopolistic area of expertise: Attacking his customer's. Greg makes some good stuff, but it's no where near as tested as he claims.I get that. All valid points.
maddog2020 wrote: ↑Fri Jul 15, 2022 9:37 am The more of these simple solutions out there in cars being tested and improved upon are good for the 928 community. GB also has problems delivering and it's being discussed at many get togethers, along with his latest tantrums. It makes no progress if he makes cool stuff and can't get it out the door. Business is about PROVIDING goods and services. His hording and attacks cost him more business than he knows.Where's the line?
worf wrote: ↑Fri Jul 15, 2022 7:37 amJust to be clear, I bought mine from Greg. That's how I knew the OP's were copies. or at least based on Greg's.milrad wrote: ↑Thu Jul 14, 2022 10:45 pm Oh I know a guy with the initials GB that's going to be really mad at you!Regardless of your opinion of GB, there’s something not-right with copying his product right down to the washers under the bolts. That takes some gall.
Condoning the behavior by buying dogpot’s copies helps ensure that fewer custom parts are made available for the 928.
milrad wrote: ↑Sat Jul 16, 2022 4:47 pm Just to be clear, I bought mine from Greg. That's how I knew the OP's were copies. or at least based on Greg's.Yeah, I knew those were Greg's.
milrad wrote: ↑Sat Jul 16, 2022 4:47 pm He also didn't completely hang up on me when I mentioned that I had bought Gretch's car But it was close!Huh. So... some bad blood between Greg and a (former) Rennlist moderator?
