- Thu Jun 16, 2022 7:18 pm
#155626
Chasing a small but pesky coolant leak recently. Localized to the Y hardine where the heater and engine return live under the expansion tank.
I am assuming I broke some petrified goo loose while pushing things around during the supercharger install.
After seeing what the OEM tank are going for, I decided to get the aluminum version from 928 Motorsports.
Knowing there is no way to see what the level is, but also knowing I haven't been able to see through the stock tank since 2009 :).
Also shopping for new level sensors made me R/R the one I have since it was working fine.
While I have learned the hard way over the years to not expect a plug and play install with any 928 Motorsport purchase, I was prepared to deal with adversity for 50% of the OEM tank cost.
The first modification required was to lower the profile on the overflow bung so that the radiator cap would actually go on the tank.
The second required different size barb fittings for the top of the tank to receive the stock hoses. Clearly the stock tank has smaller barbs. How hard is it to match your aftermarket kit to a stock 928? I can't blame it on Carl anymore, but I assume the new management is just shipping product that was on the shelf.
Anyway, the rest of the process was unremarkable after removing corrosion from the hardline.
I will say placing tank was sort of a blue hose PITA situation.
Devolved 86.5 Track car
Manual w/LS
DIY Supercharger
Manual w/LS
DIY Supercharger
