i have a large box of wiring connectors all removed from 87-91 models, just in need of help as to what they actually connect onto, and are they worth keeping.
thread might also be of use to someone in the future
pictured below is the first one, but i am sure there will be others.
another one
one more
First one is door harness: either mirror joystick or memory panel.
I think the third one is outside HVAC temperature sender connector.
Second one… dunno.
I all cases, it would be useful to name the harness from whence it came.
thanks Worf
worf wrote:First one is door harness: either mirror joystick or memory panel.
Second one… dunno.
thats my problem, they are all in one box, all have approx 6^ of wire on them, so could easily be joined back into a wiring loom, was just needing what they plugged into in case anybody needed one, or i listed them on ebay.
Well… that’s gonna suck.
I’m not sure the effort to identify those in the box will result in a positive return.
Many of the connectors are still available new from various sources.
worf wrote:Well… that’s gonna suck.
that's mainly what i wanted to know, if most are still getable and not worth a vast amount to anybody, i will just keep them,
although i did find a good 92861213100 which seems to be fitted on many 911's so might stick it on ebay, can always add a few £ to the price if it fits one of those beetle things :hiding:
By SteveG
#153386
Help: I need this connector: it is part of a '93 air bag system. It connects clock spring to air bag controller or air bag unit that follows the clock spring; a 2 pin connector. It is embossed with "BMW 1371466", no other identifying marks; the pic is of the female end. Male is attached to the clock spring. I've looked at BMW catalog, PET and google (Crutchfield), any suggestions as to supplier appreciated.
SteveG wrote:Help: I need this connector: it is part of a '93 air bag system. It connects clock spring to air bag controller or air bag unit that follows the clock spring; a 2 pin connector. It is embossed with "BMW 1371466", no other identifying marks; the pic is of the female end. Male is attached to the clock spring. I've looked at BMW catalog, PET and google (Crutchfield), any suggestions as to supplier appreciated.
hi Steve
do you have some more pictures of the connector you need?
i don't have any Porsche ones, but from that picture it looks identical to many Peugeots of the same vintage of airbag system, which i might still have some of.
i just bought a tailgate opening motor off ebay and when it came it still had the connector- pictured below - in the motor but no actual wires in it.
a word of caution, this connector can be very very tight to remove, DO NOT pull the wires to remove the connector.
part number of it is 92861213100 and is NLA from Porsche, but the actual metal terminals that go inside it are still available.
local OPC have some terminals coming from the motherland next week, so should be able to make a good connector for ebay
928 Guru Roger just confirmed these terminals fit into the above connector.
£1.78 each, a bargain and always amazes me what Porsche can still supply :drink:
Belly Pan Vents
Just got myself a Cayenne
