By Bertrand Daoust - Sun May 15, 2022 7:37 am
#149689
Hi,
I put new cam gears (after market) and now the belt is tracking a bit more to the front of the cam than it used to with the old ones.
Should I worry with this?
I turned the engine (by hand) many times.
I also put back the stock tensioner with new boot, tensioner bushings, tensioner main roller.
I didn't change the water pump (Laso, plastic impeler - new from 2017). No leak and no play.
I adjusted the belt tension (Kempf tool). It's on the high side a bit.
The timing as not been adjusted yet.
Thank you.
Thank you.
Cobalt Blue 1991 S4
2015 BMW X3 (DD)
2015 BMW X3 (DD)
