- Sun May 01, 2022 12:52 pm
#147660
starting with a pre cut 5" square 5mm thick mild steel plate, hole drilled in the plate and tapped, hole drilled in the rear cam sprocket and then securely bolted down so no mounting visible from the front face.
even got the thin green felt to stick on the under side of the base to stop the potential new owners marble desk getting scratched....
hardest part of all was figuring out how to support the mechanism gently, in the center and secure enough so as when the battery needs changing it still stays in the same place, but am now happy with what i came up with.
once the nuts are tightened at the rear the sprockets are held solidly in place.
now just need to metal bond the center washer to the front sprocket, so it is fixed in place by itself and not by the tension of the locking nut.
then need to test it make sure it keeps good time.
the base gets powder coated gloss black and i was going to powder coat the sprockets silver, but i think i will leave them as they are.
will give them a final clean and then get our body shop to give them a coat of lacquer, to preserve the look of a worn cam sprocket. as i guess the potential customers would only be 928 people, so they would know what they were looking at.
more pictures to follow.
90 GT orange
88 SE silver
87 S4 auto Diamond blue
90 S4 auto red , breaking for parts
ex
88 SE red - now Roger's
88 SE silver
ex
