#80482
Is this wired correctly?
I know the two big wires are good but want to make sure for the smaller one.
The small wire hole size only fits with that bolt (7 mm head) but what baffle me is that I thought it was on the other one (8 mm bolt head) but it can't be, it doesn't fit!
I want to make sure before I try to start the car.
I looked but could not find any pic of the connections.
Thank you in advance.
By Don Smith
#80703
Good morning Bertrand. Now that you have shown us the starter, I am kind of surprised that you didn’t paint it, and make it perfect, like the rest of your car..
Just saying. Sorry. Heck, your wife is used to missing you at the table, around supper time. Go get dirty!
Cheers
Don
Bertrand Daoust liked this
Well if we’re going to pick nits...
The zip ties should be white. :hiding:
#80750
Ho no, don't tell me I need to go back in there...
Well, I need to lift the the car to make sure there is no leaks and put back the belly pan... :wink:
By Don Smith
#80769
I thought the red zip ties were appropriate. I have never been a concours judge.....
Don Smith wrote: Mon May 17, 2021 1:47 pm I have never been a concours judge.....
And *nobody* wants me to be one.
By Don Smith
#80805
O.K., if we are going to be picky here, why not red zip ties on red cables, black ties on black cables, and brown ones on brown cables? I used to work for Bell Canada as a business technician, and we had different zip ties for different colour cables. Simple enough.
Is there a reason for only white zip ties?
Cheers
Don
Don Smith wrote: Mon May 17, 2021 3:52 pm Is there a reason for only white zip ties?
That’s what the factory used in that location. Concours judging isn’t about what makes sense... :roflmao:
Don Smith liked this
Bertrand Daoust wrote: Tue May 18, 2021 9:39 am Blue... I like blue! :)
:roflmao:
#81068
I'm going to hunt for bluish green. Any suggested leads?
By Don Smith
#81093
Harbor Freight?
#82027
WOW, these ties are even magnetic!! Put these all over your car and they will help pull the car closer to the center of the earth, increasing cornering capability. But, they might also reduce your top speed on the Autobahn if you are going uphill.
What a find! Thanks.
