By milrad
#103936
#103963
By bizman928
#137721
We are now re-manufacturing the rear Luggage area insulation foam pads that go under the carpet. you can find more information on our online shop here. Rear Luggage Insulation pad set
Daniel5691 liked this
By Charlie
#139910
Charlie wrote: Tue Mar 15, 2022 2:20 pm Someone should make these from a mold of the originals, and maybe even infuse them with the distinctive 928 "old car smell".
By bizman928
#143390
Charlie wrote: Tue Mar 15, 2022 2:20 pm Those Woodypeck pads look pretty good and are reasonably priced. I used Marshalls $20 yoga mats in closed cell urethane. Neither one is going to match the thick custom moulded pads in the later cars but they'll do the trick for sound deadening. Someone should make these from a mold of the originals, and maybe even infuse them with the distinctive 928 "old car smell".
Thanks Charlie.
Wonder if I can infuse some "New Car Leather" scent into them? :drink:
The foam has a scrim Faux leather coating on it so maybe that will help with the "New Look" smell? :rockon:
By Charlie
#144789
By bizman928
#145453
HI Charlie.
By bizman928
#154120
1985 Speedo Issues Part 2
