i gave a local graphic's company a genuine 928 S4 decal and said i need an exact copy of it, and that's what they came back with.... :kickbutt:
close but no cigar.
good gawd, what a screw up. Will make a cool conversation piece though
It5 hard for me to 5ee how 5omeone could make 5uch a 5tupid mistake.
@fpena944 Why can’t I, anymore, delete this accidental duplicate post?
By Adamant1971
#136126
Instruct them to scan the sample decal and trace it in Illustrator, they likely tried to match by using fonts. Rookie mistake by the production artist at the sign shop.
#136171
Like Adam said.
They used fonts (fastest way) instead of scanning it and clean the digitized image.
Of course it takes more time but it's the only way to reproduce something correctly.
The better the scanner (higher definition), the less time you need cleaning it to make it perfect.
BTW, It's not just the "S" that is bad.
Big rookie mistake indeed...
Adamant1971 liked this
By Charlie
#139909
It is darned hard to find the correct font. Best I've seen is called 911 Porscha but it is not quite right.
:thumbup: :rockon: :burnout:
