By Fadec
#117382
Are these springs on backwards? I’m thinking the longer spring, the one they have up front, goes on the adjuster
Those -^ are correct.
I know it seems weird.
#117640
Right, remember the short spring presses against the adjuster and keeps it from moving around by itself. When you turn it with a screwdriver it snaps against the spring to the next tooth.
By Mrmerlin
#119090
now that you have these figured out get a mirror and flashlight and verify the shoe anchor springs are properly fastened
look on the back of the hub carrier for a rib that faces forward,
the spring should hook it. common for these to not be properly hooked,
thus a short while later it sounds like loose parts in the hub
:thumbup: :rockon: :burnout:
